Old 11-22-2009, 12:56 PM   #1 (permalink)
Member # 146570
dana 44 weakness
I am building a pickup with a 1979 ford hp dana 44 with 37"-39" tires, what is the weak link or what usually breaks first?
piney1 is offline   Reply With Quote Quick reply to this message
Old 11-22-2009, 01:13 PM   #2 (permalink)
ky scrambled's Avatar
Member # 85771
lockouts, ujoints, and shafts...
Is it locked or open?
Play stupid games, win stupid prizes
Old 11-24-2009, 04:28 PM   #3 (permalink)
Member # 104275
My SAS'd 03 Ram has the same HP44 up front locked and running 37's. Holds up well. Driving style plays a part in carnage.
ce2flaco is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 08:24 PM   #4 (permalink)
mj
Member # 1919
axle shaft yokes flex and spit c clips out
then ujoint cap slides out til it hits the balljoint
get some chromo shafts that are setup for full circle snap rings
mj is offline   Reply With Quote Quick reply to this message
Old 11-28-2009, 07:52 AM   #5 (permalink)
Member # 104275
Good info!
Old 11-28-2009, 08:18 AM   #6 (permalink)
45acp's Avatar
Member # 13671
Everyone pretty much summed it up, stock shafts/ujoints/lockouts are the weak link and driving style will make a big difference in longevity. Second weak link will be the balljoints... there are two schools of thought on this. 1- run Dana/Spicers and 2- run the cheapy Autozone types and replace them every year as if they are a consumable.
However, there can be a big difference between your 37" and your 39". Example- 39" boggers on steel wheels and DIY beadlocks will be a ton heavier than say a 37" MTR on an aluminum wheel.
IMHO, you're pushing it with that axle and 37's on a fullsize if its a rock rig, but doable.
45acp is offline   Reply With Quote Quick reply to this message
Old 11-28-2009, 10:06 AM   #7 (permalink)
Member # 118007
I'm pretty much doing the same thing with my truck. What would you guys suggest be a good tire size, its not gonna be used for hard rock stuff just some trails and some rocks here in the Midwest.
glamisrnr is offline   Reply With Quote Quick reply to this message
Old 11-28-2009, 11:31 AM   #8 (permalink)
Member # 146570
disk brake covers
should I use the sheetmetal dust covers, what are the advantages and disadvantages?
Old 11-28-2009, 05:29 PM   #9 (permalink)
cslimfu's Avatar
Member # 123458
dump the covers as they are like shock boots. I always would rip the ears off the shafts with my 78, 44 with 35's.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote Quick reply to this message
Old 11-28-2009, 05:46 PM   #10 (permalink)
Banned
Member # 68805
If you're going to upgrade to chromos and pricey ujoints, might as well go for some RCV axles...'unbreakable' warranty and don't really cost much more...$1k/set. Then get a set of their drive slugs to use as spares if your lockouts break on the trail, or just run the slugs full time. Personally I'd get a couple sets of 30 spline warn lockouts and keep the slugs in the toolbag as a last resort.
TJVigilante is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 09:28 PM   #11 (permalink)
Member # 10063
Dana 60
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
