Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 02-21-2008, 09:10 PM   #1 (permalink)
jsawduste's Avatar
Member # 77571
HP Dana 60 Ford Front Axle King Pin 78-79 High Pinion
This Ford HP 60 features a nodular iron housing. Stronger then the standard housing.
It started out as a Ford ball joint front axle from a 1 ton pickup.
The short side axle tube was made longer to fit in the Jeep and other applications. The long side tube was shortened. Just like the Ford 78-79 front Dana High Pinion 60.The inners C`s have been converted to Chevy king pin. 63/64 WMS to WMS
Currently set up for Jeep YJ and CJ SOA but can be made to fit other vehicles with a spring pad change.
The axle was sandblasted and painted with red oxide primer. Not shown in the pictures but included is a heavy duty diff. cover from RuffStuff.
Housing and axle tubes with inner C`s only. Yoke included. NO internal parts
LOCAL PICKUP ONLY. SE Michigan ZIP CODE 48047
650.00
jsawduste is offline   Reply With Quote Quick reply to this message
Old 02-22-2008, 05:29 AM   #2 (permalink)
jsawduste's Avatar
Member # 77571
Pictures
Old 02-22-2008, 07:29 AM   #3 (permalink)
Member # 66736
do you have the correct axle shafts to go with this ? or any other parts ?
still drivers side drop ?
I seen you have the rear axle also, are these just housing only . I am interested in both
jwglover,97 s10 blazer,5.7 vortec,4l60e,klune-v,205,hp60frt,dana 70 detroit rear ,ORI's,44 swampers
jwglover is offline   Reply With Quote Quick reply to this message
Old 02-22-2008, 07:36 AM   #4 (permalink)
jsawduste's Avatar
Member # 77571
On the front I have knuckles and all the king pin parts. Bearings, seals , hubs. rotors available. All new stuff still in factory packaing.
Still a drivers side drop. Shock mounts also.
The rear has GLO disc brake brackets, 4 FF hubs and a set of D70 shafts. Spring perches and shock mounts come with it also.
Old 02-23-2008, 04:18 AM   #5 (permalink)
jsawduste's Avatar
Member # 77571
Up
Old 02-25-2008, 07:02 PM   #6 (permalink)
Member # 18962
Can you send contact number to webbtogo@aol.com?Interested in both F/R.Thanx
Bullfrog2 is offline   Reply With Quote Quick reply to this message
